F&^K i think ive stuffed mine now :blink:
Plastic is forgiving, if you have stuffed it you can re-polish them and fix it up.
Just use a mild cutting compound (a little at a time) and work it until there is no more, then repete until clear.
was thinking about getting farcry 2 looks sweet as, cant wait for the 20th NFS undercover :blink: and on the 27th resistance 2
Waiting for World of Warcraft : Wrath of the Lich King expansion out next Fri.... gonna be fun :) I'd buy some 3d shooters but my pc is 3 yrs old and struggles as it is
-D
Waiting for World of Warcraft : Wrath of the Lich King expansion out next Fri.... gonna be fun :blink: I'd buy some 3d shooters but my pc is 3 yrs old and struggles as it is
-D
yeah im dancing to that tune also 3700+ with a x1900xtx and whilst it was the best in its day, its day is long over
was a good card in its time i had one of them also but from factory it came overclocked and shouldnt of been i had t osend it back and AUST post lost it :blink: so they gave me $800 for insurance took like forever to get them to payout
LOL... roo... id take em fertilised at the moment.... (ya hear that ben!) lol
We'll im just in a shit mood today... I ask myself sometimes... y do i have so many male friends and only few female friends...? Then i'm reminded its because THEY F@#$ING SUCK!! Is it a requiremjent for 95 percent of the female population to be f@$#ING BITCHES?
GRRRRRR!!!!!
END RANT. :(
well im in the 5% thats good
oh yeah... women are 2 much f%#@ing trouble!
I dunno really, just something that screams different but hot ;) Oh i dont doubt my mrs is hot!
she isnt your mrs till your married damo
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
