AGREED!!!! I bet 50% of the people on here havent even got their hands dirty once while working on a car..... and go by what the twit at their local autobarn (who also has no idea about cars) advises to use... then further along that word gets passed along to more unsuspecting and out the know people as gospel...
WE WANNA SEE PROOF PEOPLE!!!!!
you dont need to work on cars everyday to know what your talking about, and there was no need to be little me by what you said ryan, yes im a beauty therapist and a girl but i know what im on about and if i dont know what you guys are talking about i dont say anything.
1. I always get my hands dirty when servicing my car or changing clutches ect ask anyone who knows me, like when we went away and i was fixing adrians intercooler pipe on the side of the road just out of Truo
2. I worked at autobarn for over 12 months and never sold them the wrong oil, plugs or anything and i sold a shit load of performance parts ie turbos/intercoolers/exhausts and had those people come back and only deal with me and they were all boys.
whos going to shutzenfest next yr??
maybe a sau drink and get pissed event.... im excited already!!!
SAU have been well represented at Schutzenfest for the past 6 years or so
Andrew (Nightcrawler) usually posts a thread, but many just know its on and turn up.
Last year we even had a team t-shirt "I'm Sotally Tober"
FK YES!!
So damn keen for shitzenfaced :banana::)
Good looking fitment also there Adrian, nice and flush so you should hopefully not get hassled for it.
Edited by AndrewJZX100
i'll be busy between the usual sau table and the work one :)
although drinking with work people can be a bad idea.............
.. not looking forward to tomorrow morning :banana:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
