AGREED!!!! I bet 50% of the people on here havent even got their hands dirty once while working on a car..... and go by what the twit at their local autobarn (who also has no idea about cars) advises to use... then further along that word gets passed along to more unsuspecting and out the know people as gospel...
WE WANNA SEE PROOF PEOPLE!!!!!
you dont need to work on cars everyday to know what your talking about, and there was no need to be little me by what you said ryan, yes im a beauty therapist and a girl but i know what im on about and if i dont know what you guys are talking about i dont say anything.
1. I always get my hands dirty when servicing my car or changing clutches ect ask anyone who knows me, like when we went away and i was fixing adrians intercooler pipe on the side of the road just out of Truo
2. I worked at autobarn for over 12 months and never sold them the wrong oil, plugs or anything and i sold a shit load of performance parts ie turbos/intercoolers/exhausts and had those people come back and only deal with me and they were all boys.
whos going to shutzenfest next yr??
maybe a sau drink and get pissed event.... im excited already!!!
SAU have been well represented at Schutzenfest for the past 6 years or so
Andrew (Nightcrawler) usually posts a thread, but many just know its on and turn up.
Last year we even had a team t-shirt "I'm Sotally Tober"
FK YES!!
So damn keen for shitzenfaced :banana::)
Good looking fitment also there Adrian, nice and flush so you should hopefully not get hassled for it.
Edited by AndrewJZX100
i'll be busy between the usual sau table and the work one :)
although drinking with work people can be a bad idea.............
.. not looking forward to tomorrow morning :banana:
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
