whats your plan of attack against the mexicano adrian??? flared guards or trackspec overfenders hahaha, give us a yell when your free, and ill come get that dumppipe too and show ya the new rims:) psi cruise tomorrow night???
well... im gonna get a flare.. cant stand the bolt ons...
um im free all day tomorrow. will be at villies fri from 6ish so u ccan swing past..
if not any day after 5:30. or i can pass it onto ryan?!
ill swing past on my way home tomorrow, bout 5 20 is that cool? :blink:
can someone download me something and burn it to cd or dvd ?
its like 700-800mb
i would download it but my parents aint payed the phone bill so subsequently , no phone line = no ADSL
i cant see this post anywhere but its in my email
was it a legal download if so yes
couple rolla updates
getting a "new" diff for the rolla on saturday :D $30
i must say the petrol tank leak is proving to be moar of a $#@% of a job than i imagined lol.... gonna give it one moar try b4 i just get a new tank for the old girl. might head to "u-pinch-it"
had an offer from a mate of mine to re-spray it too. he said if i supply paint n beer, and lend a hand he will do it. will do this after i grab a straight passenger side front quater panel.
oh.. and did u find those meshies scandy ??
no luck yet mate. few places i couldve left em though, ill let you know.
ill swing past on my way home tomorrow, bout 5 20 is that cool? :)
yeh for sure!!!
let me know when your home tomorrow adrian and ill swing past. Spend some more quality time together. ;)
ill msg u about 3.. gotta get motivated to get the water pump and acc belt :down:
and nissan dont have the hose :)
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
