yeh i should have listened! sorry ryan... :)
thats something i can deal with ne ways!!! and its puerly my fault.. at least everything ryan has done has been 100%
adrian= fail hahahahhaa
ryan = WIN
lol dont be so hard on yourself...
shit happens and its happened to all of us. At least the motor is in top condish.
Andrew ill do another...:happy:
LOL just got a letter in the mail informing me I 'failed to vote' in some local election circa early September. They have a space on the back that lets me chuck in an excuse as to why I didn't rock up (to try and avoid the MASSIVE penalty of $20 :P)
Might put something in there like 'I was sleeping in and cbf' or 'I do not care for your political mumbo jumbo' or something stupid. They'll reject it and I'll have to pay the $20 but who cares, it'll waste a bit of their time :D
either that or I'll pay with a drawing of a spider :rofl:
Edited by AndrewJZX100
here ya go Andrew :rofl: this ones on the house ill have to charge you for the next :D
hahahahah damn I should've looked in here before I wrote my smart arse letter, could've printed that out and done a snail mail version of the recent email joke :P
had an adventure in the rolla today :P
had another crack at fixing the fuel tank... seems to hold up, so i took her out for a cruise.
could still smell petrol, so was gonna pull off brighton road n suss it out, then the old girl stalled. we pushed her into a carpark and had a look......... the carby was leaking fuel from this shoddy rubber seal that was in the re-build kit straight onto the turbos exhaust housing :S
so glad it stalled or me and my mate would have had a ride in a fireball.
upgrade time!!! gonna get a webber in there, or maybe a carby from a camira :D:rofl:
got it towed to my mums place, and i saw thomasino drive past in his 180, i waved but got a blank stare lol
hey as some of you may know ive only got 1 head light at the moment due to some sort of wiring issue in my car.
anyone here got some skills and willing to help me out n take a look? i can cough up some $ or do a krusty burger exchange.
ive already checked its not the globe :P and ive changed the switch inside the dash which is known to be troublesome in 32s, so somewhere along the wiring line a rat has had a snak or something.
Edited by Inline 6
Just finished making up the actuator extension screw on bit that attaches to the flapper.
Bit of a bastard welding it then i got slag inside the thread few problems as per normal when working on cars. Now to take it for a spin. :)
Driving n/a with the flapper disconnected starts to get to you after a while. :)
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
