yeh i should have listened! sorry ryan... :)
thats something i can deal with ne ways!!! and its puerly my fault.. at least everything ryan has done has been 100%
adrian= fail hahahahhaa
ryan = WIN
lol dont be so hard on yourself...
shit happens and its happened to all of us. At least the motor is in top condish.
Andrew ill do another...:happy:
LOL just got a letter in the mail informing me I 'failed to vote' in some local election circa early September. They have a space on the back that lets me chuck in an excuse as to why I didn't rock up (to try and avoid the MASSIVE penalty of $20 :P)
Might put something in there like 'I was sleeping in and cbf' or 'I do not care for your political mumbo jumbo' or something stupid. They'll reject it and I'll have to pay the $20 but who cares, it'll waste a bit of their time :D
either that or I'll pay with a drawing of a spider :rofl:
Edited by AndrewJZX100
here ya go Andrew :rofl: this ones on the house ill have to charge you for the next :D
hahahahah damn I should've looked in here before I wrote my smart arse letter, could've printed that out and done a snail mail version of the recent email joke :P
had an adventure in the rolla today :P
had another crack at fixing the fuel tank... seems to hold up, so i took her out for a cruise.
could still smell petrol, so was gonna pull off brighton road n suss it out, then the old girl stalled. we pushed her into a carpark and had a look......... the carby was leaking fuel from this shoddy rubber seal that was in the re-build kit straight onto the turbos exhaust housing :S
so glad it stalled or me and my mate would have had a ride in a fireball.
upgrade time!!! gonna get a webber in there, or maybe a carby from a camira :D:rofl:
got it towed to my mums place, and i saw thomasino drive past in his 180, i waved but got a blank stare lol
hey as some of you may know ive only got 1 head light at the moment due to some sort of wiring issue in my car.
anyone here got some skills and willing to help me out n take a look? i can cough up some $ or do a krusty burger exchange.
ive already checked its not the globe :P and ive changed the switch inside the dash which is known to be troublesome in 32s, so somewhere along the wiring line a rat has had a snak or something.
Edited by Inline 6
Just finished making up the actuator extension screw on bit that attaches to the flapper.
Bit of a bastard welding it then i got slag inside the thread few problems as per normal when working on cars. Now to take it for a spin. :)
Driving n/a with the flapper disconnected starts to get to you after a while. :)
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
