how much for the n1's? my car needs a chrissy present
If your interested in a cheap pair of N1's mine will be coming off over christmas cause im upgrading to Garretts... only thing the seals need replacing on em as oil is getting on my manifold... so if your interested jus send us a pm if not i'll jus post em up in the for sale section.
yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeehhhhhhhhhhhhhhhhhhhhhhhhhhhhhaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaawwwwwwwwwwwwwwwwwwwwwwwww
Just got my 34 back from the workshop. Took it there to replace the water pump, and not only does my car now stay icy cool (old pump was corroded and cavitating badly), but the rattle from my engine bay is GONE! A few of you would have heard the rattly beast on the cruise last week or at bowling a while back - and it is NOT top end issues - it was just the damn water pump. So, no rebuild for me after all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I am heading down to Vili's to get my calendar at about 7:30pm - will catch up with some of you there
PM sent
well don't nick off straight away, hang around for a bit & I'll try to get down there to
If there not firing its multimeter time to see if the problem is with the loom or the injector.
i can hear clicking on all of them i think.. i just hope there not f**ked otherwise its gonna get expensive!!!!
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
