i'll guess 100 rwhp.
also you spelt "harbor" wrong.
ahhh, very good, a man that knows his twins................around 100 is pretty much what I expected out of a 2 cyl tractor.
the big improvement comes from how crisp the throttle is now........no longer do I give it a fist full and a weeks notice to respond, lol
I've still got a splitting headache from being in that small chamber with the whole place vibrating, the sound was awesome and shook every bone in my body.
I also found out that my digital speedo won't read past 199kph (as you'll see in the video when I get round to it) it was still accelerating in 4th with 2 gears to go.
you gonna bring it down to vilis again pete ?
yeah if the weather is good I might
I wanna get the Brutale out to stretch her legs too. Might be there also this Friday.
Pete, I'm hoping to have the TLR sorted by next week. Big v-twins and race systems rock! :thumbsup:
... for the record, my TLR has 125rwhp and smoooooth torque/power curves (and a dyno sheet somewhere from Lushies to prove it) :D
Edited by RubyRS4
So the R35 can't handle 400kw? :) Piston split in half ... another R35 even blew its engine being reversed off the docks.
Pete, get the new Supra mate :(
Edited by RubyRS4
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
