finally i think the airport in Bangkok will finally open tommorrow so i can f**kEN come home if not i gotter travel a further 3 hours at 12 am to a military air base to catch a flight at 8am.............i just wanna come home and pick up my car and so Ryan can put my new bakes on........all ive been doin is shopping and wasting money coz im that bored
Could be worse man, at least your comin back....see ya soon!
might be a bit of an out there chance
anyone got a CAD file for the bottom half of an RB20/25 inlet plenum (the runners to the block)
mate of mine is going to be knocking up some custom forward facing plenums, and needs a cad file (or at worst a spare lower plenum half that no-one wants) so he can get started
who's ya mate work for matty? how is he making it?
he works for etsa lol, he's got a bloke who can cut the stuff out of 16mm aluminium
he did briefly explain it but i was driving home from work when he rang me
all good, he had started to mod a standard plenum (until i got highlighted the negative side of that), and he said it was hard to weld new material to existing. was going to be much easier to go all new instead
MAN i just replaced the negative battery terminal clamp... and god damn that was a fricking pain for something hardly significant at all. I cant be ass doing the positive - I'll do it when it becomes a problem. Damn the idiot that designed the battery in the boot directly under the parcel shelf.
ruby those vids remind me of a certain kmart tyre place
now i was in mums sic commo when i was waiting on a very busy to turn right, was there with crazy traffic for like 5min atleast.
finally gap about to happen and i look up at kmart at this fool that appears to be about to snake me and pull out before i can from the private rd. he rolls out sure enough and i notice he aint turning i think who the f is this idiot driving and look in the drivers seat no 1s there :rolleyes: the car rolls by scraps my mums commo on the side and i run after it trying to stop it from slamming into others cars. was having trouble stopping it from the window yank so stupid me stands infront and go's for the rugby scrum stop lukily i got it too stop and it didnt push me over but yeah tools tried to fix up the car half assed when i bailed them out of way more damage to other cars. dudes like fk forgot the hand brake
Edited by Inline 6
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
