finally i think the airport in Bangkok will finally open tommorrow so i can f**kEN come home if not i gotter travel a further 3 hours at 12 am to a military air base to catch a flight at 8am.............i just wanna come home and pick up my car and so Ryan can put my new bakes on........all ive been doin is shopping and wasting money coz im that bored
Could be worse man, at least your comin back....see ya soon!
might be a bit of an out there chance
anyone got a CAD file for the bottom half of an RB20/25 inlet plenum (the runners to the block)
mate of mine is going to be knocking up some custom forward facing plenums, and needs a cad file (or at worst a spare lower plenum half that no-one wants) so he can get started
who's ya mate work for matty? how is he making it?
he works for etsa lol, he's got a bloke who can cut the stuff out of 16mm aluminium
he did briefly explain it but i was driving home from work when he rang me
all good, he had started to mod a standard plenum (until i got highlighted the negative side of that), and he said it was hard to weld new material to existing. was going to be much easier to go all new instead
MAN i just replaced the negative battery terminal clamp... and god damn that was a fricking pain for something hardly significant at all. I cant be ass doing the positive - I'll do it when it becomes a problem. Damn the idiot that designed the battery in the boot directly under the parcel shelf.
ruby those vids remind me of a certain kmart tyre place
now i was in mums sic commo when i was waiting on a very busy to turn right, was there with crazy traffic for like 5min atleast.
finally gap about to happen and i look up at kmart at this fool that appears to be about to snake me and pull out before i can from the private rd. he rolls out sure enough and i notice he aint turning i think who the f is this idiot driving and look in the drivers seat no 1s there :rolleyes: the car rolls by scraps my mums commo on the side and i run after it trying to stop it from slamming into others cars. was having trouble stopping it from the window yank so stupid me stands infront and go's for the rugby scrum stop lukily i got it too stop and it didnt push me over but yeah tools tried to fix up the car half assed when i bailed them out of way more damage to other cars. dudes like fk forgot the hand brake
Edited by Inline 6
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
