Good luck to all the boys going on the Toy Run today. Stay safe.
Yeah that Twilight movie was pretty shit to be honest. To much loving, not enough slaughter. Also its obviously going to be a series of movies be the end of it. Great :)
Lol. Like half way through the movie I needed to piss so bad, but I didn't wanna miss anything because Jen would of explained it all to me later. I love the " we can only play Baseball during Thunderstorms" bit.
i think may have been one of the many scenes where my attention waned somewhat.
the only thing that movie has going for it is the reasonably cool soundtrack.
now, 'in bruges', thats a cool movie.
i miss my stagea
want her back now
bets on dyno queen rwkw figure - I say 230 at 1.1bar this tune (poncams, head)
and perhaps 245 next tune (HKS AIC-4 additional injector controller, & Sard intake manifold setup with 2x700cc Sard injectors~ mounts near bov)
:sad:
I took my car to Pedders in Morphett Vale on Friday afternoon, good bunch of guys there. They spend an hour with me looking over my suspension looking for any problems and also got a very good quote on an adjustable front sway bar, when i left i asked them how much i owe'd them and they said not to worry about it. So if ya live down south i'd def recommend taking your car to them if you need any suspension gear :)
Edited by DSTROY
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
