Good luck to all the boys going on the Toy Run today. Stay safe.
Yeah that Twilight movie was pretty shit to be honest. To much loving, not enough slaughter. Also its obviously going to be a series of movies be the end of it. Great :)
Lol. Like half way through the movie I needed to piss so bad, but I didn't wanna miss anything because Jen would of explained it all to me later. I love the " we can only play Baseball during Thunderstorms" bit.
i think may have been one of the many scenes where my attention waned somewhat.
the only thing that movie has going for it is the reasonably cool soundtrack.
now, 'in bruges', thats a cool movie.
i miss my stagea
want her back now
bets on dyno queen rwkw figure - I say 230 at 1.1bar this tune (poncams, head)
and perhaps 245 next tune (HKS AIC-4 additional injector controller, & Sard intake manifold setup with 2x700cc Sard injectors~ mounts near bov)
:sad:
I took my car to Pedders in Morphett Vale on Friday afternoon, good bunch of guys there. They spend an hour with me looking over my suspension looking for any problems and also got a very good quote on an adjustable front sway bar, when i left i asked them how much i owe'd them and they said not to worry about it. So if ya live down south i'd def recommend taking your car to them if you need any suspension gear :)
Edited by DSTROY
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
