how many 35s we got here? theres just the white 1 correct im sure i woulda heard if there was another 1 by now
i know someone that is covinced she seen a silver 1 even after 20min of are you sure it wasnt white and are you sure it wasnt a g35
lol @ this guy:
http://www.news.com.au/adelaidenow/story/0...5005962,00.html
Mr Lahane said his plan was to render her unconscious so he could steal back the $100 he had paid for sex just minutes earlier.
Someones taken GTA4 pretty seriously :)
lol @ this guy:
Whats even more funny is the prostitute's boyfriend was in the next room :) Why would you date a prostitute, and if you did, why would you tag along with her to work? :D
what, so you can claim it on tax? Pretty sure you'll have trouble explaining that business related expense to the ATO.
:) Imagine claiming expenses like whips, candle wax, D cell batteries, pregnancy tests, VD tests :)
lol, in one of our government programs, you have to enter their overseas occupation, current occupation and preferred occupation, and prostitute is an acceptable entry, has its own code and everything :)
LOL thats not a big back yard, (my dam is bigger than that)
this is mine
a comfy 100 achres (lots of room for a private trst track and drag strip if it wasnt so hilly (no flat quarter mile strip :) )
i wouldnt mind tryin that out with my 4wd guy :)
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
