Well lucky me i had my car egged last nite and didnt realise until this afternoon. So know not only have a got PAINT CHIPS but also marks were the egg yoke hase been sitting. I HATE WANKERS who F**K with other ppls car coz there better.
END RANT
END RANT
unlucky dude
i had some pricks egg my commodore once , caught em and taught em a lesson .
ended up being wankers that used to try give me shit at school
its such a low thing to do.
had some exhausts quoted today, 3" mandrel bent pipe, centre muffler, resi, and drift pipes, et wanted $880, aaa only wanted $550, for the same thing...
my car will be at ET tomorrow getting a 3 1/4" straight through catback system which i have asked them to make "AS QUIET AS POSSIBLE BUT WITH MAXIUM FLOW" was quoted $750 in mild steel
does anyone no where i can get a set of R33 GTR rims/tyres from or even just rims???
Japanese import spares wanted $1,200 with nearly bald tyres $1,500 with average tyres
Japanese motorsports wanted $1,500 with good tyres and $1,300 for just the rims
Wheel Worx dont have any but said they usually sell for around $1,000 or under
does anyone no how much they should be selling for???
i need ASAP
i need ASAP
Those prices sound about right. 32 gtr rims go for about 800-900 and 34 gtr rims go for about 2k.
how does she go dan?
its still at MORPOWA
they found that the exhaust was restricting flow because of the mufflers (which i had changed to make it quiet) was making a strange noise from them while on the dyno, had a look and found they wer'nt straight thru mufflers and prob packed full of wateva is in em to make them quiter
also Simon thinks going from 19" rims to 16" rims has made a difference on the dyno something to do with the circumference of the wheel or sumthing which affects the load on the dyno so it gives a lower reading than what its capable of
so its off to ET tomorrow on a flatbed for new exhaust and hopefully i can find a set of r33 gtr rims
my car gets tune tomorrow....
anyone know how to wire in wipers??
mine dont work... will give favours hehe...
just need them done before the weekend!
working wipers should give u an extra 40rwkw i think Adrian........lol
goodluck tomorrow man hope you a get a good reading, what rwkw are you aiming for???
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
