Just noticed Andrew is now a super mod....when did the change over occur? I knew about Pete becoming a mod but how did Luke manage to become one? :cheers:
and cubes lisnt supermod or mod anymore.... end of an era :)
but now andrews ban stick is much more bigger :)
Haha, f**k you all :) Banhammer time now :cheers:
In all seriousness... I was talking to Andrew about Pete becoming mod, he mentioned that they possibly needed one more so I threw my name in the hat. I hope I can serve you all and do the best I can, I'd like to think I'm fair and level headed when it comes to what I say/do on the forums :)
I'd like to also give a big shoutout to Cubes who did us so well for many years, you'll be missed buddy, sorry you felt the need to move on
Has anyone here brought one of those HID kits from the group buy section??? Im thinking of buying a set.
i was gonna get a set but the seller doesnt even know wat ones fit a 32gtst...
idiot!
ahhh good choice in mods! good work :cheers:
there is no 2nd place brown noser award, what will we do without cubes were doomed doomed i tells you
time to
in all seriousness who's the official r32 mod now? hello equal distribution of power plz :)
Edited by Inline 6
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
