Google-translate that shit! It has 1 owner, original k's with books/receipts for the dash change. Cleanest 32 GTR I've seen in a long time: http://www.kurumaerabi.com/?page=syousai&a...mp;stock_id=403
Google-translate that, too! Another clean as 32 GTR: http://wwww.kurumaerabi.com/?page=syousai&...mp;stock_id=348
And that's why I love 32 GTR's. F*cking porn: http://page4.auctions.yahoo.co.jp/jp/auction/d88463104
Cheers for the links CRoNic!
And when did we change mods? Was there a vote? Was there a ceremony? Did it involve rituals with the Ban Stick?
It involved several litres of treacle, some gaffer tape and an echidna. Don't ask. Luke and Pete probably don't want to talk about it.
-D
those bitches aint cheap.
anyways, looking through the jap import site, looks like they got some cool shit in the latest container, might have to head down and spend some money tomorrow...
^^^silver 1 looked in better shape i reckon, i wouldnt be so sure of those k's on the blackie even with reciept he paid them money think they may be willing to help him sell by shortening the k's but then any 32 is subject to the clock winding back procedure.
nice pics of plastic bags they took :D also the angles they choose kinda hides the areas i have lil pety flaws on mine
Just spent an hour ripping out the back seat from the GTR. f**k me, it's difficult! 2 tiny clips hold it in, but it's like they're welded in!!
Rofl, thats what I thought. I tried and failed.
Then I saw Jack do it. I guess being a professional makes all the diff, cause he had em out within a minute, and back in within two ;P
-D
Seems to be just that one side/hole that wont go in... I tried the other end and went in fine, tried that hole on the other side of the car no good either but the other end goes in fine.
I'll be in need of an alignment anyway after replacing the tie rod ends, putting standard springs back in and will need to replace the bushing on the front castor rods or replace the whole rod. About how much and where to get the lock bar engineered around the metro areas do you know? I remember someone mentioning something about $250 :thumbsup:
Rory Thompson does the lock bars, 0414948028 or in ph book under rory thompson services, on rundle road salisbury south (next to post office)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
