mm turning 21 was good, my insurance premium has dropped by $600 for my next year :) but my agreed value has dropped $2k :)
it wouldn't be cause you turned 21 that your insurance dropped its because the agreed value has dropped
.7
you generally wouldnt need to go any lower
Damo - that logic test, 1 of the questions i didnt like was #5
Answer 5.
a) Where there is poverty there is crime.
b) There is crime in Camberwell.
- Therefore there must be poverty in Camberwell.
Invalid. There may be crime where there is poverty, but it does not necessarily follow that wherever crime is there is poverty. There is plenty of crime occurring in wealthier circles.
where there is poverty there is crime is a truth statement its not guessing
there is crime in camberwell is again a truth statement
so how can it be invalid where not discussing how wealthy camberwell is just stating there is crime there
sweet..can they go lower due splitfires?
Ideally want a higher gap not a lower. I higher gap gives a better ignition to the fuel but it also is weaker spark which makes it susceptible to being "blown out" by the intake charge.
Anyhow the accepted gap is 0.8mm if you have split fires then you should be able to run a bigger gap but it'll be trial and error to find out how big and I wouldn't go over 1>1.1mm anyway.
Edited by D_Stirls
hmmm.... ok i think there at .8 atm... thats wat they are from the box?
i can just feel the car hold back constantly then be ok the hold back due to missing...
ill open them up more... trial and error i guess..
what is the last number on the part number? If it had some thing like BKPR6ES-8 then it is 0.8 but if it was -11 or didn't have a number at the end then it's 1.1mm
If you are having spark problem then opening them up won't help you need to close them up, but if you have split fires then you shouldn't be having spark problems. you will know if they are breaking down because it'll sound like it not running on all cylinders where as you are saying it's feeling like it's being held back which isn't spark. It's probably got more to do with ignition timing.
Edited by D_Stirls
Surely dropping my agreed value from 23,900 to 21,850 wont bring my insurance premium from 2098 p/a to 1500 p/a. if thats the case, ill set agreed value at 18k and pay no insurance.
Rhys, yep just car, got the info from my policy renewal letter, expires early Feb.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
