Not bad eh?
Still don't quite understand how those sports players get paid that much when there are people out there such as teachers/nurses who have 100x more important jobs and get paid a pittance... oh well... consumerism at it's best. You can market sports stars, you can't market a teacher/nurse
Just be careful with paypal because if there is a dispute generally they side with the buyer, and will return the money to them and take it from your account. There are a few dodgy people that have realised this and are routing it.
My missus was selling a car and there was a buyer that said that they would only pay with paypal even though they came an looked at the car in person, the only reason that i can see that they wanted to do this is because they would going to start a dispute after the car was delivered and try to get the money back. Then it would be up to us to try and get the car back which would be in their name by then.
Also when getting large amount of money ($150>) paypal will take 3-5% when you go to transfer the money out of your account, so make sure you charge the buyer 5% more than the sale price if they want to use paypal.
might have something to do with the thousands of people that fork out big bucks to watch him play :) unfortunately they are not willing to do the same to watch a dr at work. its prob small amount compared to how much the owners make from ticket sales and endorsements
dale is it better to give them bank details for them to pay that way?
it's better for you as the seller as once the money is in your account there is nothing they can do to get it back, but because of this they might not be willing to pay that way. As a buyer i prefer to use paypal as there is some recourse if you get the wrong part or the part is substandard (in a dispute on paypal at the moment over a Exhaust manifold that is utterly crap) but as a seller i prefer to use direct deposit, because of what i mentioned above.
Edited by D_Stirls
Quote sliding performance...
Happy driving everyone.
Go Hard At The Track, Then Go Home.
Or for those with GTR's
Go Hard At The Track, Spin A Bearing, Then Go Home. On a trailer.
HAHAHAHAHAHA funny
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
