20" vault chromies at the front and black steelies at the rears... massive street cred increase right there :yes:
FS: set of Steelies. Comes with 2 extra if you're going to bust out huge skids and want to keep that line going down the street.
Unknown offset... but when they're ablaze, it doesn't matter.
:cool:
:cool:
I typed in Commodore Steelies and Commodore Stockies and Commodore Skids and this is what it came up with:
Look at that first picture of the Commo ripping it up... notice how the passenger is wearing a helmet, but the driver isn't? What a fail! Maybe the passenger window is open and he's wearing the helmet to protect his head when the tyres burst and rubber fly's through the window :yes:
:cool:
On another forum I saw some modified steelies with monster dish on a Rolla,... looked phat
that could be another option for the 32 .... would be different
SOLD MY NINJA 250R on my way to buy a 2006 yamaha R1 50th anniversary edition woohoooooooooo
Is that the yellow one in traditional yamaha colours? if so they look very nice! but i don't like the way R1's ride.
If anyone wants a set of steelies i have a set of 16x7.5 ~+35 5x114.3 that i'll let go for $30 each or or $100 for the whole set (and i'll throw in the plastic hub caps). They'd be perfect for drifting as they would be easy to straighten and who really cares for $30, or for some rep' points on the street.
Edited by D_Stirls
im being told fully bored out rb25 rehousing with hi flowed internal will make close to 300rwkw..
anyone else think this could happen? i didnt think the 25 turbo is big enough even after being bored out
Yeah it probably could but would cost you a packed to do it properly
I have 2 x standard GTR turbos that are steel wheels and my car make 300kws on 16psi of boost
Adrian, who told you that?
I had a what you call a 'bored out' rb25 rear with larger steel wheel with my gt2871r and it was on the limit at 250, hence why i bought the new turbo.
