20" vault chromies at the front and black steelies at the rears... massive street cred increase right there :yes:
FS: set of Steelies. Comes with 2 extra if you're going to bust out huge skids and want to keep that line going down the street.
Unknown offset... but when they're ablaze, it doesn't matter.
:cool:
:cool:
I typed in Commodore Steelies and Commodore Stockies and Commodore Skids and this is what it came up with:
Look at that first picture of the Commo ripping it up... notice how the passenger is wearing a helmet, but the driver isn't? What a fail! Maybe the passenger window is open and he's wearing the helmet to protect his head when the tyres burst and rubber fly's through the window :yes:
:cool:
On another forum I saw some modified steelies with monster dish on a Rolla,... looked phat
that could be another option for the 32 .... would be different
SOLD MY NINJA 250R on my way to buy a 2006 yamaha R1 50th anniversary edition woohoooooooooo
Is that the yellow one in traditional yamaha colours? if so they look very nice! but i don't like the way R1's ride.
If anyone wants a set of steelies i have a set of 16x7.5 ~+35 5x114.3 that i'll let go for $30 each or or $100 for the whole set (and i'll throw in the plastic hub caps). They'd be perfect for drifting as they would be easy to straighten and who really cares for $30, or for some rep' points on the street.
Edited by D_Stirls
im being told fully bored out rb25 rehousing with hi flowed internal will make close to 300rwkw..
anyone else think this could happen? i didnt think the 25 turbo is big enough even after being bored out
Yeah it probably could but would cost you a packed to do it properly
I have 2 x standard GTR turbos that are steel wheels and my car make 300kws on 16psi of boost
Adrian, who told you that?
I had a what you call a 'bored out' rb25 rear with larger steel wheel with my gt2871r and it was on the limit at 250, hence why i bought the new turbo.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
