20" vault chromies at the front and black steelies at the rears... massive street cred increase right there :yes:
FS: set of Steelies. Comes with 2 extra if you're going to bust out huge skids and want to keep that line going down the street.
Unknown offset... but when they're ablaze, it doesn't matter.
:cool:
:cool:
I typed in Commodore Steelies and Commodore Stockies and Commodore Skids and this is what it came up with:
Look at that first picture of the Commo ripping it up... notice how the passenger is wearing a helmet, but the driver isn't? What a fail! Maybe the passenger window is open and he's wearing the helmet to protect his head when the tyres burst and rubber fly's through the window :yes:
:cool:
On another forum I saw some modified steelies with monster dish on a Rolla,... looked phat
that could be another option for the 32 .... would be different
SOLD MY NINJA 250R on my way to buy a 2006 yamaha R1 50th anniversary edition woohoooooooooo
Is that the yellow one in traditional yamaha colours? if so they look very nice! but i don't like the way R1's ride.
If anyone wants a set of steelies i have a set of 16x7.5 ~+35 5x114.3 that i'll let go for $30 each or or $100 for the whole set (and i'll throw in the plastic hub caps). They'd be perfect for drifting as they would be easy to straighten and who really cares for $30, or for some rep' points on the street.
Edited by D_Stirls
im being told fully bored out rb25 rehousing with hi flowed internal will make close to 300rwkw..
anyone else think this could happen? i didnt think the 25 turbo is big enough even after being bored out
Yeah it probably could but would cost you a packed to do it properly
I have 2 x standard GTR turbos that are steel wheels and my car make 300kws on 16psi of boost
Adrian, who told you that?
I had a what you call a 'bored out' rb25 rear with larger steel wheel with my gt2871r and it was on the limit at 250, hence why i bought the new turbo.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
