Mitch, the rough figure you're looking at for a standard RB26 from a front cut and then installed, old engine removed, etc would be roughly 7k I'd say (RB26 front cuts without the box and turbo's are roughly $5k these days :cheers: )
which i wouldn't bother with ,
i don't even have $50 let alone $5k
have u also checked under the oil cap?
the head gasket might be flowing water into the oil
if that looks like iced coffee = BHG.
know this all to well from blownig a few 7m's in my old cressy (they dont seem to like high compression)
7M's didnt have the right torque figures for the head from factory tighten them down a little more (there is info on the net somewhere) and its all sweet
How do you calibrate that meter?
with one of these
