any1 giving away a 2 seater lounge??? wanna put 1 in my room, just bought the new HP touch screen computer n everything is wireless (mouse, keyboard) so i dont have to sit at a bloody desk all the time
from memory there we some seats in the for sale thread (dw just checked they were yours :ermm::P
hello everyone
Ok just got back from Dyno. Boost controller having trouble holding boost as it spikes to 25psi and by the end its at 19.5psi.
1st Run wheel spun its titties off so Pete had to tighten the straps more (made 279)
2nd run right up the top off the torque range it lost traction again and the graph fell away (made 323.8)
3rd run the heat had set in but still managed 323.2 and still wheel spun a touch up the top of the torque.
If i can get the boost to hold more stable who knows possible. I will post the dyno graph in the RB25 upgrade thread sometime today.
I owe all this to AD (aka180or200)who has done an absolutely brilliant job on tuning my car. Your a legend mate.
Needless to say i'm stoked with the outcome.
yea and we got one person to thank for it.
Niel is only doing his job....if you have a defectable car then you run the risk of being picked up....it's simple....we have regulations there for a reason and if your car isn't within those regs then pay the price to get it fixed.
Thats one reason why I've removed the mod stuff from my Stagea. Even the exhaust which has a big muffler and tip is very quiet for its size. I took it to the exhaust shop 3 times until I was happy with its noise level. Still got the cat in it too, and fitted a larger resonator, even has a new O2 sensor to ensure its running clean. My car looks great with the body kit and thats about all I need right now. I have my bikes and track days if I wanna go fast.
Getting the silver S1 Stagea registered soon now I've replaced the waterpump, O2 sensor and timing belt. Engine and gearbox has been serviced. I'll be driving that around next month when the black S2 Stagea's rego runs out. The silver stagea is as stock as they come. I can't sell it, so I might as well drive it.
Edited by RubyRS4
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
