^^my thoughts exactomely!
but, pete has taste, why go from 34gtr to a run of the mill landcruiser?....... hmmmmmm
twin turbs v8 soarer maybe? nahhhhh...............
mmmmmmmmmm im thinking too hard and my brain hurts when i do that
what brain...............???????????????????????????
ahaha
ive also got 2 R33 stockies with good tread.
was bored, so i spent the last hour or so poking round the engine bay of the 200, just seeing where everything went, how much of a pain it is to get to shit, etc etc, then i remembered, i occasionally have a missfire on load higher in the rev band, so i pulled the plug cover off, and started pulling the coilpacks out. i was expecting it to be the coilpacks, but no, theyre in mint condition, so i went for the plugs, and shit, theyre well f**ked...
so thats second on my shopping list next pay, new plugs, not too keen on forking out uber dollars when for iridiums when copper plugs will probably do fine, just require a change quite a bit sooner, what plugs are people using? cause the only plugs i can find listed for the 200 are iridiums...
Edited by scandyflick
i had iridium's but that was because i bought them 2nd hand brand new cheap this time i have copper
i found this info Dave
NGK Spark Plug
1984-1988 Nissan 200SX
"NGK V-POWER SERIES SPARK PLUG -- Nickel Alloy Electrode Tip Material, 0.044 in. Gap Size, 6 Heat Range, 14 mm Thread Size, 0.75 in. Reach, 5/8 Hex Size, Gasket Seat, Resistor, Solid Terminal, V-Grooved Center Electrode, Projected Tip, JIS Height, 90 Degree V-Power Center Electrode, Economical Performance And Improved Ignitability Over Standard NGK Spark Plugs, OE And Racer Approved, Features Lower Ignition System Voltage Requirements, Delivers Greater Ignitability And Performance Over Conventional Spark Plugs, Trivalent Metal Plating Has Superior Anti-Corrosion And Anti-Seizing Properties, Offers Increased Fuel Economy And Lower Emissions, Highly Durable Against Electrical And Chemical Wear, Good Performance Spark Plug"
Fit Note: INTAKE, Gap 0.044, BCPR6E-11.
i still like the sound of the 4.5 diesel v8 tt
how heavy is the 200 series pete? she'd at least tip the scales at 3t surely
2.7 tonne Matty
Like I said at the beerfest.......if I attached a rope from the new truck to your house, either your house would no longer be there or your street would be excavated!
Needed something with decent pulling power for the new caravan that I just bought..........now to sell the the 5yr old Windsor Rapid.
2.7 tonne Matty
OMG ... Pete has turned into an caravan touring old man! :blink:
Would you like some tea with your scones while you watch the campers roll by? :P
Edited by RubyRS4
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
