^^my thoughts exactomely!
but, pete has taste, why go from 34gtr to a run of the mill landcruiser?....... hmmmmmm
twin turbs v8 soarer maybe? nahhhhh...............
mmmmmmmmmm im thinking too hard and my brain hurts when i do that
what brain...............???????????????????????????
ahaha
ive also got 2 R33 stockies with good tread.
was bored, so i spent the last hour or so poking round the engine bay of the 200, just seeing where everything went, how much of a pain it is to get to shit, etc etc, then i remembered, i occasionally have a missfire on load higher in the rev band, so i pulled the plug cover off, and started pulling the coilpacks out. i was expecting it to be the coilpacks, but no, theyre in mint condition, so i went for the plugs, and shit, theyre well f**ked...
so thats second on my shopping list next pay, new plugs, not too keen on forking out uber dollars when for iridiums when copper plugs will probably do fine, just require a change quite a bit sooner, what plugs are people using? cause the only plugs i can find listed for the 200 are iridiums...
Edited by scandyflick
i had iridium's but that was because i bought them 2nd hand brand new cheap this time i have copper
i found this info Dave
NGK Spark Plug
1984-1988 Nissan 200SX
"NGK V-POWER SERIES SPARK PLUG -- Nickel Alloy Electrode Tip Material, 0.044 in. Gap Size, 6 Heat Range, 14 mm Thread Size, 0.75 in. Reach, 5/8 Hex Size, Gasket Seat, Resistor, Solid Terminal, V-Grooved Center Electrode, Projected Tip, JIS Height, 90 Degree V-Power Center Electrode, Economical Performance And Improved Ignitability Over Standard NGK Spark Plugs, OE And Racer Approved, Features Lower Ignition System Voltage Requirements, Delivers Greater Ignitability And Performance Over Conventional Spark Plugs, Trivalent Metal Plating Has Superior Anti-Corrosion And Anti-Seizing Properties, Offers Increased Fuel Economy And Lower Emissions, Highly Durable Against Electrical And Chemical Wear, Good Performance Spark Plug"
Fit Note: INTAKE, Gap 0.044, BCPR6E-11.
i still like the sound of the 4.5 diesel v8 tt
how heavy is the 200 series pete? she'd at least tip the scales at 3t surely
2.7 tonne Matty
Like I said at the beerfest.......if I attached a rope from the new truck to your house, either your house would no longer be there or your street would be excavated!
Needed something with decent pulling power for the new caravan that I just bought..........now to sell the the 5yr old Windsor Rapid.
2.7 tonne Matty
OMG ... Pete has turned into an caravan touring old man! :blink:
Would you like some tea with your scones while you watch the campers roll by? :P
Edited by RubyRS4
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
