^^my thoughts exactomely!
but, pete has taste, why go from 34gtr to a run of the mill landcruiser?....... hmmmmmm
twin turbs v8 soarer maybe? nahhhhh...............
mmmmmmmmmm im thinking too hard and my brain hurts when i do that
what brain...............???????????????????????????
ahaha
ive also got 2 R33 stockies with good tread.
was bored, so i spent the last hour or so poking round the engine bay of the 200, just seeing where everything went, how much of a pain it is to get to shit, etc etc, then i remembered, i occasionally have a missfire on load higher in the rev band, so i pulled the plug cover off, and started pulling the coilpacks out. i was expecting it to be the coilpacks, but no, theyre in mint condition, so i went for the plugs, and shit, theyre well f**ked...
so thats second on my shopping list next pay, new plugs, not too keen on forking out uber dollars when for iridiums when copper plugs will probably do fine, just require a change quite a bit sooner, what plugs are people using? cause the only plugs i can find listed for the 200 are iridiums...
Edited by scandyflick
i had iridium's but that was because i bought them 2nd hand brand new cheap this time i have copper
i found this info Dave
NGK Spark Plug
1984-1988 Nissan 200SX
"NGK V-POWER SERIES SPARK PLUG -- Nickel Alloy Electrode Tip Material, 0.044 in. Gap Size, 6 Heat Range, 14 mm Thread Size, 0.75 in. Reach, 5/8 Hex Size, Gasket Seat, Resistor, Solid Terminal, V-Grooved Center Electrode, Projected Tip, JIS Height, 90 Degree V-Power Center Electrode, Economical Performance And Improved Ignitability Over Standard NGK Spark Plugs, OE And Racer Approved, Features Lower Ignition System Voltage Requirements, Delivers Greater Ignitability And Performance Over Conventional Spark Plugs, Trivalent Metal Plating Has Superior Anti-Corrosion And Anti-Seizing Properties, Offers Increased Fuel Economy And Lower Emissions, Highly Durable Against Electrical And Chemical Wear, Good Performance Spark Plug"
Fit Note: INTAKE, Gap 0.044, BCPR6E-11.
i still like the sound of the 4.5 diesel v8 tt
how heavy is the 200 series pete? she'd at least tip the scales at 3t surely
2.7 tonne Matty
Like I said at the beerfest.......if I attached a rope from the new truck to your house, either your house would no longer be there or your street would be excavated!
Needed something with decent pulling power for the new caravan that I just bought..........now to sell the the 5yr old Windsor Rapid.
2.7 tonne Matty
OMG ... Pete has turned into an caravan touring old man! :blink:
Would you like some tea with your scones while you watch the campers roll by? :P
Edited by RubyRS4
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
