IMO, George Bush and his public speaking will be sorely missed.
'The vast majority of our imports come from outside the country.'
- George W. Bush
'If we don't succeed, we run the risk of failure.'
- George W. Bush
'One word sums up probably the responsibility of any Governor, and that one word is 'to be prepared'.'
-George W. Bush
'I have made good judgments in the past. I have made good judgments in the future.'
- George W. Bush
'The future will be better tomorrow.'
- George W. Bush
'We're going to have the best educated American people in the world.'
- George W. Bush
'I stand by all the misstatements that I've made.'
- George W Bush
'We have a firm commitment to NATO, we are a part of NATO. We have a firm commitment to Europe. We are a part of Europe '
- George W. Bush
'Public speaking is very easy.'
- George W. Bush
'A low voter turnout is an indication of fewer people going to the polls.'
- George W. Bush
'I have opinions of my own -- strong opinions -- but I don't always agree with them.'
-George Bush
'We are ready for any unforeseen event that may or may not occur.'
- George W. Bush
'For NASA, space is still a high priority.'
-George W. Bush
'Quite frankly, teachers are the only profession that teach our children.'
-George W. Bush
'It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it.'
- George W. Bush
Nice find Damo
OMG ... Pete has turned into an caravan touring old man! :blink:
Would you like some tea with your scones while you watch the campers roll by? :P
Haha, you're a funny boy........I've been touring in a caravan for 5 years, nothing has changed bud......time to cut back on work and live a little!
Will eventually get into a '94 V-Spec 32 if I can find a mint one.
anyone want a slab of piss (or cash adjustment) to take my injectors out? i went thru the hassle last time so cbf doin it again, got em supposedly fixed and now there still leaking, so have to take em back to the workshop.
Edited by rhys5169
Pete:
My dad recently bought a 200 series cruiser GXL also (TTV8D), nice car! Fuel consumption isn't as great as toyota lead you to believe, BUT your right, enough torque to pull a house down :P
When pulling his 2T (fully loaded) camper trailer around NT/QLD mid last year he was averaging about 18L/100 from memory, whereas unloaded he would get about 12L/100. That was sitting on Highway speeds whenever possible, and more often than not 80+ on the dirt "highways".
Nice cars though :P
Pete, a few pages back, I managed to find a heap of 32 GTR's (not V-spec's) but they had genuine 30,000k's and stuff like that on them... basically garaged for years! They were going for about 25-30k.
It wouldn't be hard to find a mint condition one! There's still plenty left in Japan. You just need to fork out a bit for them.
Rhys, with your injectors, did you just replace the O ring? The actual injector might be split (happened with mine)
supposedly they where all looked over, cleaned, seals replaced and tested. but i dont belive this for a number of reasons
Damo & Chronic, nice finds boys but I won't even look at a GTR unless it's a V-Spec and mint late model V-Specs are indeed rare.
Pete:
My dad recently bought a 200 series cruiser GXL also (TTV8D), nice car! Fuel consumption isn't as great as toyota lead you to believe, BUT your right, enough torque to pull a house down :)
Nice cars though :)
yeah I drove my VZ Berlina to Melbourne and left it at the Toyota dealer then drove the 200 back........at highway speeds I got 10.5L/100.........will be interesting to see how it goes towing 2.5 tonne.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
