Lol yeah my missus has a 10kg cat called Mr. Moo...
It's actually huge. It eats a massive amount of food, vomits, and then eats more food!! And then runs outside and attacks other cats. It's always eating! And vomiting!
It's loud as f*ck when it's running over the roof... sounds like someone jumping on the roof.
Yeah +1 for pets.
I used to have a rabbit called Munchkins... until it died of a twisted bowel.
Poor thing.
It was 7 years old, which is about right for a normal healthy rabbit.
I even had a leash for it. Took it around the backyard... until it somehow got out the leash. Then spent the next 3 hours running around the yard trying to catch the thing! They run and jump so quickly... and burrow even quicker! That thing was crazy. We caught it by leaving out a bowl of raw oats for it (they love oats) and then threw a towel over it - CIA style.
yeah hes a ragdoll. They meant to be the most placid cat, but i think i got the reject cos he is so full on.
Im moving out in 2 weeks from my nans house, im gonna leave him with her cos shes so attatched to him, it wouldnt be fair to take him from the place hes lived his whole life so far.. so im thinking about going to the pound to get a new pet, they desperately need homes.
lol cronic, i use to have like 14 rabbits at one stage! :P I was the sucker who took pets nobody wanted and yeh.. they bred like rabbits.
1 of them escaped once, lived in my neighbours garden. We staked out the garden for 3 nights to catch it, used the good ol blind it with a torch trick. It died a week later anyway :S
Haha yeah we were going to get another rabbit one time... answered a ad in the paper, got to this house and this girl was like the cat lady off the Simpsons except with rabbits.
She had cages upon cages of rabbits. We walked past a dead one, and she said "oops, I was meant to throw this out earlier" and just picks it up and throws it in the bin.
She even plunked this huge rabbit on us... it weighed like 20kg and was as big as a small baby! It was crazy.
We left that place pretty quickly.
Couldn't believe she had so many rabbits!!
I had to leave my cat at my mums when I moved out. She lived in the country and its not fair to bring here into suburbs. :P
I used to have horses back in the day, my boy Casper died a few years back but had a good life, he was old.
Brutas was a give away cos the guy did shiftwork and left him locked up all day in a tiny courtyard. Absolute nutter when I got him but he learnt quickly and is an angel now.
My cat is psycho! Beats up on our staffy. Attacks ANYTHING moving or not.
But boy does it know about it when the little f**ker digs its claws into my lounges! :P
Its name is "Jet" ... but I wanted to call it "Scud". Which is more appropriate as its a furry scud missle!
The Labrador is bloody dumb. As in so stupid I think it actually is retarded. Its fat and lazy, always wants food and hogs all the affection.
Yep. You pretty much summed it up. Our current dog:
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
