Lol yeah my missus has a 10kg cat called Mr. Moo...
It's actually huge. It eats a massive amount of food, vomits, and then eats more food!! And then runs outside and attacks other cats. It's always eating! And vomiting!
It's loud as f*ck when it's running over the roof... sounds like someone jumping on the roof.
Yeah +1 for pets.
I used to have a rabbit called Munchkins... until it died of a twisted bowel.
Poor thing.
It was 7 years old, which is about right for a normal healthy rabbit.
I even had a leash for it. Took it around the backyard... until it somehow got out the leash. Then spent the next 3 hours running around the yard trying to catch the thing! They run and jump so quickly... and burrow even quicker! That thing was crazy. We caught it by leaving out a bowl of raw oats for it (they love oats) and then threw a towel over it - CIA style.
yeah hes a ragdoll. They meant to be the most placid cat, but i think i got the reject cos he is so full on.
Im moving out in 2 weeks from my nans house, im gonna leave him with her cos shes so attatched to him, it wouldnt be fair to take him from the place hes lived his whole life so far.. so im thinking about going to the pound to get a new pet, they desperately need homes.
lol cronic, i use to have like 14 rabbits at one stage! :P I was the sucker who took pets nobody wanted and yeh.. they bred like rabbits.
1 of them escaped once, lived in my neighbours garden. We staked out the garden for 3 nights to catch it, used the good ol blind it with a torch trick. It died a week later anyway :S
Haha yeah we were going to get another rabbit one time... answered a ad in the paper, got to this house and this girl was like the cat lady off the Simpsons except with rabbits.
She had cages upon cages of rabbits. We walked past a dead one, and she said "oops, I was meant to throw this out earlier" and just picks it up and throws it in the bin.
She even plunked this huge rabbit on us... it weighed like 20kg and was as big as a small baby! It was crazy.
We left that place pretty quickly.
Couldn't believe she had so many rabbits!!
I had to leave my cat at my mums when I moved out. She lived in the country and its not fair to bring here into suburbs. :P
I used to have horses back in the day, my boy Casper died a few years back but had a good life, he was old.
Brutas was a give away cos the guy did shiftwork and left him locked up all day in a tiny courtyard. Absolute nutter when I got him but he learnt quickly and is an angel now.
My cat is psycho! Beats up on our staffy. Attacks ANYTHING moving or not.
But boy does it know about it when the little f**ker digs its claws into my lounges! :P
Its name is "Jet" ... but I wanted to call it "Scud". Which is more appropriate as its a furry scud missle!
The Labrador is bloody dumb. As in so stupid I think it actually is retarded. Its fat and lazy, always wants food and hogs all the affection.
Yep. You pretty much summed it up. Our current dog:
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
