i must be the only person on here actually driving their car today.
I drove today!
Bloody coilpacks. started to run on 5 :( need to get a new set, ne one got a spare liying around buy any chance. Sick of the 32 sounding like a rexxy
Anyone actually heading to BDO ?
nothing really special this year.
prodigy, hot chip, and a couple others will be good.
good perv, and always a big day out.
Cog are playing, theyre pretty damn good... listening to em now - I'd go, if it wasnt so hot and I wasnt working
-D
yeah cog are good. butterfly are ok too.
like em. but dont love em.
Thought u mighta heard of hot chip ?
Im pretty sure you were the dude I spoke to about boards of canada , art of noise etc.?
Anyone up for a late night drive tonight (like 11-12), Just fitted some new pads (750 degree pads for Mallala) and need to bed them in and it too hot during the day. Nothing too energetic as i need to get my car on the dyno to check the AFR's after the last few changes.
Just PM me if your interested and i'll get back to you around 10.
Meeting up in the NE preferably or centrally if there's interest.
Edited by D_Stirls
this is beyond a joke.
this is our 3rd power cut since 5 pm yesterday.
and our 2nd today, power went off at 1, come back at 5 only to have it back off ten mins ago..
once again FUUUK YOU ETSA!!
thanks for yet another sleepless night.
campbelltown... wierd thing is, its not as many houses as last night, and the street lights
are still on :) (last night they where off...
still, either way i look at it, im hot, and this sucks major cock!
ETSA Current outages are listed here:
http://etsa.com.au/current_interruptions.jsp?xcid=852
campbeltown isnt on there so something is not right.. your not part of the current rolling blackout so it must be a fault/issue with your supply.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
