Sorry for the coming long post, but I received this excellent 'on topic' email from my Mum just yesterday .... unfortunately I think a lot of guys on here will experience this in the coming 2 years of recession under the Krudd government. :)
The moral of the story is that rather than give below average income earners $1k to blow on pokies, booze, turbos etc (which is exactly what happened last handout and only benefited the hoteliers of Adelaide, not the economy in whole whatsoever), the govt should ease tax on businesses, so that 1. they manage to stay in business through the tough times, and subsequently 2. many people actually keep their jobs as a result of the businesses not going under and massively effecting the economy.
what a revelation Andrew.......could not have been said any better!!
Do you know that the majority of Australia's workforce is employed by small business, not big industry?!
Smarten up people and stop misdirecting your winging & whining to your boss but rather the gov.
On the money nightcrawler.
However I feel most people are entirely blaming Krudd for these troubled times.
Has alot to do with China. Alot to do with the US.
I feel Krudd took over government in very different times. Very different to the early 90s etc.
Its a different world. I wouldnt want to be in his shoes
At the end of the day we are still a lucky country. So I try not to whinge too much.
True. good fact.
But; The government is handing out lump sums to help the small businesses.etc (so they say) People will spend more with the lump sum. I agree some people will just spend it on the pokies.
In contrast; Buying a turbo. buying a swimming pool. Getting your car fixed up. are all helping small businesses. to a certain degree.
don't know about us living in the lucky country anymore......that may have been the case a few years ago
Did anyone see the latest figures on home affordability around the world??
Only 10 years ago we were amongst the most affordable places on the planet to own a home, we have now moved up to around the top 10 of the least affordable on the planet......and I'm talking Adelaide here, not just Sydney!!
sled did you read alexander downers collum in yesterdays advertiser? its the only thing worth reading in that shocking paper, he finally let loose on what he thinks of rudds handling, very good read. i'll see if i can find a web link
and mind you, they are referring to an average household income (which usually means X2).
Anyone have any idea what the so called average income is at the moment........judging by the average age on these boards, only a small % would be on it and even less over it...........and if you don't have a missus to contribute, you're stuffed!
Here's one of the quotes from the above link:
The Deposit Power/REIA Affordability report for the September quarter found 36.6 per cent of household income was needed to cover average home loan repayments.
That tells me that it would be close to 100% of some of your wages! :)
no I didn't see it bud
this whole thing has me shaking my head. everyones going on about how awesome its going to be to get $1000, but they dont realise the long term cost of this. its billions of dollars in deficit over the next couple years, surely people can see the problem in that?
Thats deff one point alot of people dont address.
Without a partner or business counterpart how are you supposed to afford buying a house.
I dont go back on my word when saying we are a lucky country.
But I must agree that its very hard to afford and pay for a house. Almost seems you have to have no life and sit at home and constantly pay off your mortgauge with a lovely interest involved.
That's an awesome letter there Andrew... read it to my olds, they agreed 100% and have added it onto their mailing lists to send out to others. It's sad that people can realise this but somehow the government doesn't, or doesn't want to
but what can we do about it? the Majority of the population voted him in!
here, here!
ohh bull, the liberals just rode a wave of success, and they didn't capitalise when they had the oppurtunity to do things to help soften the blow when the eventual bust came.
And what goes up MUST come down it's simple.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
