Hahahahahah so you're saying if the liberals were in power the global financial problems wouldn't of happened. This is easily the post of the year and it's only feburary. Hate to break t to you but with the current situation I'll think you'll first d whoever is in power would have some sort of deficit in the budget.
+1
And what do the liberals do? They sit on a pile of money and do nothing. Part of kruds plan is to invest in infrastructure which will create a few hundred thousand jobs. We are not that isolated if we were we getting be getting this cold after the USA sneezed.
stol came over last night to help put the car up, cheers Andy muchly appreciated
after spraying him with rp7, and getting a screwdriver stuck in the cat for 20mins, finally got a .8mm round hole thru the cat
just want to release enough backpressure to stop boost drop
seems to have worked mostly, probably need to do again but slightly larger say little finger width thru the centre
sounds like a fair bit of work. one thing though, hole in the cat probably makes it effectively useless. just take it to an exhaust shop and have it modified completely.
ive been up all night. night shift = days off are stupid. might buy an intercooler just for something to do today.
also, omfg!
stock z body (pulled rear gaurds) with 18*10 -7 front and 18*12 -13 rear... do want.
hey i didn't mind that red Volvo on top gear last night does that mean i have homicidal tendencies towards stagea's, should i see my doctor if pain persists :):D
naa you'll come to your senses when the heat goes......hot weather can make you delirious :)
I'm showing my age here, but my mum would always tie a sixpence in the corner of my school hanky and told me to keep it for a rainy day.........moral of the story is, better to have it than to owe it.
Do you actually understand how he plans on going about this......cause he doesn't, not judging by the way he has hit my business since Johnny was shown the door.
lol Brendan, expect a visit from the RSPCA :(:P
by the way, .8mm is only 32 thou.....the size of a needle hole?
Oh goody! A non-political topic. :(:D
I'm thinking of getting another cooler too ... a stealth unit to replace my home made jobbie :)
figured id change it up a little. keep my adoring public guessing. :)
i just want to replace the tiny stocker. put a couple borrowed temp probes in piping both pre and post-cooler just to see how it worked. and well, it doesnt work too well. and whatever kit i buy with be copping a can of crinkle coat + satin black to the piping and a can of satin black to the core itself. mmmm, stealthy.
Edited by scandyflick
A TV/electrical question:
I have a Samsung 32 inch flatscreen LCD in my bedroom. I bought a HD set top receiver box for it, and a cheap HD aerial from ebay. That didnt work, so yesterday i bought a dick smith HD indoor/outdoor aerial. I connect it, tune the tv, only picks up SBS through the set top box. SBS, SBS HS, etc etc. then i plugged the aerial straight into the tv itself, and tuned that, and it picks up SBS clear as day, but 7, 9 and 10 are all snowy. Would it be better to mount the aerial outside? Im so over snowy tv. Could it be the tv itself?
Brendan just bite the bullet and get your self a AMperformance high flow cat you wont regret it
i think there about $360ish will confirm price when i can get in contact with him, and you will probably pick up a couple of psi from it being able to breath
edit price confirmed $360
Geez pete you are old bud lol
sixpence isnt that like centuries ago...time for using dollars and cents :(
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
