hahaha you're welcome :happy:
But no-one is going to get the $950. No way this waste of money is getting through .... the Libs let it go once, but twice is just bad joojoo
*Sigh* I have nearly finished typing my valuations from today. I have my 1st job at 8:15am in the morning and my last one at 5:30pm tomorrow .... so home around 6:30pm, see the wife and child from some dinner, then around 6 hours of report typing tomorrow night :ninja: I had better go to bed. Soon.
Hahah I hope you're hungry mate, cos you have one hat to eat :ninja:
http://www.smh.com.au/news/national/stimul...3423344567.html
"Stimulus package passed after overnight debate"
-D
Heard on the radio this morning KRudd having a go at Malcolm Turnbull for halting the handout, claiming "he's hurting the economy but not allowing this money to reach our schools, hosptials ...". What a load of bullshit. It'd certainly reach the pokies, bottleshops and anything in between, maybe some school fees paid (but they need to be paid regardless), but def not our hospitals. Anyone who believes what KRudd says doesn't deserve the money anyway. :happy:
*God I tried so hard not to get in on this topic, but can't believe the rubbish coming out of KRudd's gob*
Edited by RubyRS4
MMM you're right. I'm going straight to the bottle-o and buying $950 worth of Wild the sphincter of the universe and Sparkling Ale
-D
You have no idea of my education level let alone my income.Believe it or not but your not the first person to go to uni. And poor you forgoing 4 years salary to do it, that sounds really tough, i'd be interested to know what 3 year uni course you did.
And why would i want a shitty job where i never get to see my family and all I do is complain about working on here.
Hmm and by your calcuations i earn't 120,000 dollars on that 12 grand tax i payed you know as i keep 90% of my income.
Once again lets ask around if you payed 45k tax you earnt around the 140 grand. I think most people would be happy to take that salary and pay the tax.
i believe that red, is in fact the best colour. discuss.
also, im fairly sure my internet is bouncing off the limiter. shit.
i think we should just admire Dave's new profile pic: THE BARRACUDA!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
