Confirmed. Turbo core is rattly and on its way out. $1700 to rebuild.
Do I go with rebuilding it or would a 3071 be better with less lag?
For $1700, what do I do people? :P
mate, now that I've returned the R back to stock, I've got a spare one you can have.
just harden up & do it!
For $1700, what do I do people? :)
who is that with Roo
f**k 1700? a guy in melb hiflows for 800? You can get more power out of a 3071r :) but do you wanna upgrade injectors, fuel pressure reg, fuel pump, z32afm, etc etc?
with any turbo upgrade those parts will need upgrading to make full potential of new turbo
bah, rebuild/hi flow a vg30 rubes, keep the popo happy and still makes Very good power.
atleast speaking from my experience anyway
fixed
ring Bill Keen from ATS even if its just to pick his brain he built my high flow and its awesome he also built 180or200's aka Adrian and his flows good too
Hows this for good.
have a few drinks with one of my fav musical groups from LA two weeks ago.
Watch their second show last thursday. have a few more drinks. and chit chat. real nice people.
Ask me and a friend to come party with them in Las vegas in May. then stay with them in LA where they live. show us around etc.
My answer was yes. :)
oooooh I might be heading to Vegas in May to catch up with some friends from London .... who is the band?
Ruby my mate has a Garret 3071 for sale, rb housing, lines, done 3000k's, made 280rwkw on his 34. Price ~$2200
Croydon Racing Developments are doing them for $1450 new. :)
Who was selling an Apexi turbo recently ... Rad32?
The 3071 seems to be the one to go for.
Pretty heavy band. 'as blood runs black'
Think I wrote something in wasteland awhile back about them. when I was a tad wasted myself.
usually into electronic stuff. But I can appreciate good music.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
