fancy a lol
the guy that owns "dragon" is a member of streetcredit..... he is quite convinced that its a 180
here is a quote from the owner
HI A MEMBER OF SMASA AND I GOT 180SX CALL DRAGON SHOW CAR > ALL AIR BRUSH S15 REBUIT MOTOR 4 NOS 220KWS AT THE REAR REGO AS 2SEATER PULL ON SOUND 138 DS IT WILL BE A THE CAR SHOW FEB 8TH EMAIL ME 4 INFO THE DRAGON
His engine is not a S15 engine, it doesn't have the bump at the front of the rocker cover for the VTC solenoid that al the S14 & 15's had.
Also I though he was claiming he had 260rwkw and that he was running a T51R.
questions !
can i use an rb25 air con compressor on an rb26 and do i need to have the fans n crap on the front of the car behind the bonnet latch thingy
do rb26 pistons and cranks go into rb30 blocks
how do i tell if im missing the big aircon box thats usually under the dash
(air con blows air out so i assume it aint missing lol! )
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
