I'm Crying Inside!!
Thanks To Those Yellow Bumps On The Road (Accidentally Hit One) One Of My Front Coilover's is snapped :thumbsup:
holy fark that sucks! hks coils?
I reckon he has coils from china made of bamboo :D
So sad to hear that Tom
You sounded like you actually liked those coils a lot
Hope all goes well and you can get another coil at a decent price
I think your right steve....china bamboo by the sounds of it
was in the same situation you are a few months back, thought about going cheap king springs & shocks, but ended up waiting for a few more weeks, and sacrificing a little.
and ended up getting HKS adjustable coilovers and they were well worth the wait, makes a huge difference.
Plus second hand coilovers aren't that expensive these days, seen sets for like $800.
I'm Crying Inside!!
only 12 spots left in the SAU AFL Fantasy Footy league! see sig.
also, any (decent) offers for my wheels?
You'll never sell those rims... you may as well get a metal saw and cut them into bits so u can see as 'Genuine DamoR34 paperweights, limited edition vpec 3'
-D
Damo have you tried selling those wheels in the main for sale section
also have the price a bit lower i guess.....coz you can get those Doriftotecks for like $1400 for 18's
just a suggestions
loose $200 or so bucks to get rid of those wheels i think is worthwhile
or another suggestion is wrap them in semi slicks for some mad track days
craig wtf were u searching for!!!
Edited by Krishy
Do R34 skylines have factory immobilizers?
How do you know if your alarm complies with AS406??
Trying to answer stupid insurance questions!........
Stupid indeed, who asked you that, all the times i've asked they just wanted to know if i had an alarm, not if it complies with AS406 etc..
lol, conversation with JustCar
"how can i help you?"
"oh i installed an alarm in my car, just wanted to update you guys"
"yep thats fine, anything else?"
That's not what happened with me.
They didn't care at all about an alarm, they wanted and I mean mandatory a black wired 2 point (at least) immobiliser. So I had to have removed an alarm/immobilisor I had put in the car a week earlier that did not comply and have another installed that did comply.
Threw $380 down the toilet because I didn't do my homework in regards to Aus standards and what just car insurance required
finished the big front mount, lol looks funneh - sitting tooooo low
got to go back an inch or two, but that means re-lipping something I cant do here.
grrrrrrr, still bolted up ok just yeah, too low atm.
going in for touchup tune in 2 weeks so will get it fixed then; my knees cant be bothered atm in all honesty :D
drives well tho
ahh ok i did mine over the phone, r34 i suppose it would say on the alarm/immobilizer unit itself AS406, but since it's from japan, which i believe they did have a factory immobilizer, probably not.
Just tick yes lol, and upgrade to an aftermarket alarm from like Tisonics etc
Edited by Murry33
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
