I think you'll take back that statement once it's been rebuilt...
MAYBE.
its just finding someone to build it and finding a job that doesnt require a car so that i can raise more money
how sad , my race weapon is my daily , ha!
im gonna kick myself for suggesting someone else actually do this,
but have you considered applying at the casino, mitch? weve got pretty high staff turnover at the moment, so were constantly hiring and training new staff, first few weeks sucks with no pay (training, not sue how thats changing with the eb's), but once youre through that, its close to $20 an hour, for as many hours a week as you want...
Edited by scandyflick
i have thought about it but i dont want to deal black jack or deal with people on a retail side of things etc as.
what sort of job's are there available because the only ones ive seen on the Sky City site is experience croupiers and HR Administration job's ;/
MAYBE.
no luck with fours n more?
most croupier jobs are no exp necessary. but theres main cage cashiers, security, gaming machines, valet parking, anything related to food and bev, just jump on the website and fire off some apps, its shit work, but if you need quick money, well...
cheers dave , will give it some consideration :thumbsup:
i dont like em. lol unless they are the cafe primo ones lol
lol Your not alone Cara, I cant stand pancakes either, gut bombs!!!! :)
give me waffles anyday..lol :O
and Damo my R34 front lip goes into production in a few weeks , all CF and fully functional venting..?
be up for some orders after a checking the arc on another front bar? cost TBD but hell of a lot cheaper then Nengun and better venting.
hope to have it done for the show and shine
Guest CleanAndSimple
know this is not that wanted section but nobody reads it anyway,
by any chance anyone got any 6" or 6.5" speaker covers, like just the plastic covers, my stock skyline ones have broken to pieces :) dont really want ugly holes there (Y).
will pay for them, just don't have to cash to do my sound system.
Hey,
Does anyone know how to get the faded stuff off the headlights when its on the inside? I use cut and polish to make them clear on the outside but one of them must have had mosture on the inside at some stage....
Cheeeeeers
Penny,do you have a photo of it?
it has a broken seal and needs to be removed and split apart to fix properly, dont attempt unless your confident in repairs, very fragile and expensive to replace if done wrong!!
to fix them to perfection use aircraft windscreen polish, or megulars m105 works pretty good to rid the haze followed by plastic polish.deeper scratches can be sanded out with 2000grit wet sanding followed by the above.
to dry them pop out a globe and use a heat gun or hair dryer on low heat, then put the globe back in.
hope that helps
Troy
I swear u guys dont know what you're missing. Some pancake recipes are shite (and dont even compare instant pancakes to the real shit).... you get a good recipe for home made french crepes, you wont be going to work that day...
waffles are cool too but i'd rate a good crepe/pancake over waffles anyday. sounds like u guys have been eating pikelets instead ;D
-D
pretty sure i have some, silver with a cross pattern no mesh . free to a good home
or i would suggest any car audio shop, they normally have boxes under the workbench overflowing with them?
-D
pancakes and pikelets, both foul..lol
my grandma makes some pancakes with 7/up or mtn dew in them. the bubbles make the pancakes thin and slightly crispy when they pop while cooking. much better then thick pasty doughy ones. some old fossil recipe but still not that crash hot on pancakes.
Edited by sapphiregraphics
man thats just lazy, shes using the soda in place of bicarb ;\ disgusting
a good pancake is rubbery and flexible... light but not aerated.... when u put salt and aeration into a pancake it becomes a pikelet (and i find them damn near inedible)...
imho the thinner the better - thick, aerated pikelets are like uncooked bread, which is a total degustation misnomer
-d
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
