Yeah I gotta get mine replaced so I'll be lashing out for a set of RDA front slotted rotors too. Theyre not as expensive as I thought they'd be either.
-D
rda are awesome value get a full set of rotors for the same price of 2 dba
-D
Just got mine off the SAU group buy, in 4 days.lol
and cheaper for 4 then buying 2 from anywhere else in town
Ben look into the group buy mate
i got a set of 4 for my 33.....$***delivered and was here in 2 weeks
so definately recommend that guy in the GB section
"edited by SLED"
I arranged it last week thru the grp buy.
-D
Seriously?! Yeah!! Slotted are a shit load better than just standard.
Improved stopping distance, improved feel, etc. I even went from a cross-drilled set to a slotted set and noticed a huge difference.
They improve braking power, basically. That and a good set of pads!
Most properly modded street cars, you'll find with slotted rotors. As well as all the HSV's and FPV's that came out the factory, and a few BMW's.
everyone going slotted?
curious, do slotted rotors go through pads faster than standard flat rotors?
Well for me Damo the slotted rotors feel a whole lot better
i havent noticed much brake pad wear but only had them in for like 4 -5 months now
plus i had to go slotted as you can as luke (enr_034) how stuffed my stock rotors were mate
if anything they make the pad last longer. they do have more bite which increases wear but the groove also assists in cleaning the brake dust off the pad and venting it out so its not actually trapped between the rotor and the pad, and that itself helps the pad to stay alive a bit longer...
You'll still have benefits with cross drilled however many cross drilled rotors are prone to stress fractures due to the fact that they are drilled after the rotor is forged, whereas the slots are actually shaped within the forging/casting process. You'll notice RDA also have the gold passivated rotors with slots and 'dimples'. The dimples are done during casting and dont go the entire way thru the disc, so theyre much hardier. cross drilling isnt so useful for street work (lets face it, its there for cooling so its mainly for racers)... slotted is more than enough for any street car.. if your slotted rotors aren't doing the job on the street, then thats the time you consider caliper and disc diameter upgrades... or switch to a prius
I've already added a cusco brake cylinder brace and braided brake lines and those two improve the feeling/response of the brakes quite a bit. The new rotors should really seal the deal, I can't see myself needing bigger calipers or disc diameter...
-D
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
