i would say go with the RB25 Mitch
that way the can will be legal and wont have much hassles
but your call really
if the motor just needs a small scale rebuilt then do that
whatever you do mate goodluck with it and hopefully see you out and about soon
Im not sure what the law is but if you change back to a 25 you may need to go through regency so that they can approve the new engine number to make it legal. You may want to ring them and find out.
At work today thinking about next yr. Wondering if i should save up spend 10k on a engine or spend a month holidaying in Japan.
hmm hard choices.
Don't forget a 1/3 of that has to come my way :D
Pete it was finnaly good to meet you and have bit of a gas bag about the old Valiants!
yeah it was good James, cheers for the chat
I would also like a washer bottle that fits in despite my ic piping. I assume if Damo got one made up it would fit my car too? I can supply my oem washer bottle motor if he wants to integrate it (which would be preferable).
yeah, he'd do that with the OEM gear (basically it would be a solid replacement to the factory plastic ones)
oh, and cos i can
man i still lose my shit every time i watch this :(
:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
Getting given 10 massive bags/boxes full of baby goods, and having to sort them out while massivly hungover= FAIL
finding 6 xxx DVDs in the bottom of one of the boxes, without wendy noticing = WIN!
i cant believe how many cops were out last night as it was!!!!! sooo many more than friday night
i know, i came from down pt noarlunga, there was an drug test van as ya head down into porties (just afta ya come round from murray rd), plus 2 separate RBTs on Anzac Hwy
surprisingly no cops at the bay or anywhere near hindley / rundle. most of their hindley fun has been taken out by closing that section off on a sat nite
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
