ca wouldn't even heat up a kettle :)
but srsly, CA in a keto would be fun, gotta look after the engine tho. 90% of CA's are old and thrashed, no wonder they dont last. If you think about the pre 91 silvias with CA's, that was 18-19 years ago, thats old in engine years.
all aboard the failboat.
http://www.skylinesaustralia.com/forums/To...93-t260430.html
holy shit! someone run this turbo
Garrett GT6041R
Information:
This large frame turbo is suitable for race applications.
Housings Available: 1.25 A/R, 1.47 A/R
Power: 2000hp
The price is still dropping :)
http://www.j-spec.com.au/list/index.php?ID=14119
yep not wrong on that one damo
if i remember correctly he made 185 on the boostworx dyno
not a bad power to weight ratio on that beast
That was 185 kw with a 10mm hole in the intercooler piping where a blanking plug came lose and fell out. That won't be happening again, now with added loc-tight.
What's with all the CA haters here, anyone would think it's a skyline forum. The only problem with CA's is that a lot of them have had a hard life and they haven't been well maintained, If you get one that's been treated with respect they make a good RELIABLE little power house. Have a look at the graph below, that's on a standard bottom end.
Here's the new graph from a couple weeks ago on a 36 degree day, and that's after i lost 10kw by going back to the factory manifold which we gained back by 1 more psi in boost, also gained 400 RPM in response with the factory manifold;
Edited by D_Stirls
such a nice and smooth curve and the power is coming nice and early as well
ahh now i know why you only made 185 on that day....would have liked to see this figure there
so am i reading it right Dale....your actually loosing 400rpm in response by using aftermarket manifolds?
I knew something wasn't right in the day because it was sssooooo rich, if you remember the exhaust manifold was also cracked at the turbo flange, when i took the turbo and manifold off it all made sense when i saw the 10mm plug had falled out of the compressor outlet.
Yep was getting full boost just over 4000 before but now it's more like 3700-3800 rpm, but at the cost of kw. Was making 216kw with the old manifold but with the factory manifold it was making 203kw, with some more tuning and the extra psi or so we got it back to around the same figure as the old manifold.
Earlier power = Torque so would have gained a few Nm in torque, but i don't have a graph with that on it.
Edited by D_Stirls
yeh damo ca in a keto would be a handfull!
CA's don't even need oil :)
Have had nothing but bad experiences with CA's (spun bearings, lack of women throwing themselves at the car when I drove past, etc).
But seriously, if you're going CA... just do yourself a favour and get a RB20!
Use the CA for a paper weight or something.
its ok i thought about rb20 in the keto lol..
but just abit too much work.. and would be way insane!!
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
