theyre stupid is what they are.
and i cant even put into words how properly ridiculous this thing would be;
Years ago a Peripheral ported 26B, 4 x rotor job won Le Mans. If I remember correctly rotas were banned soon after
Rotarys are effectivley a 2 stroke engine (even thought they don't actually have a stroke) that is why they use more fuel but that is also why they produce so much power with such small displacement.
How about these apples;
Edited by D_Stirls
oh, ive bought a set of pads for the s14 as i can hear the current ones squealing, nothing special, just something to keep my brakes going til i get my qfm's and rda's, but uh... ive never changed pads on 4 pot brakes before, so would anyone be willing be help out?
they are the easiest setup to change i have encountered. the rears require a bit of fiddling to "screw" the piston back in, but they are still 10 times easier than my ford rears that also screw in and you need a special tool to do it (which i didn't have).
3 sided rotor is kinda like having a 3 cylinder 2 stroke with rotor apex seal opening/closing ports as seal passes/exposes the port
Yeah sucked big time. I still think the best days were when we had BMW's, Volvos, Ford Sierras, GTR's in the ATCC
Holden v Ford is a little boring imo
Word to mutha..... its a boganfest atm.... the group A's were much more interesting to watch.... too many rules in motorsport these days. I just wish it didn't come down to R&D budgets.... I reckon some of the early grand prix's in the 30's would be more interesting to watch than todays F1..
-D
-D
F1 which I've been following for nearly 25 years now has been pretty good still up until the last 4 or 5 seasons. Cutting capacity back to 2.4L V8 from 3L V10 and then the engine development freeze and then controlled ECU and now they've f**ked 'em up with new aerodynamics. Should be an interesting first few GP's this year....
Yep there is 3 power "strokes" per 1 revolution of the rotor but there is 3 revolutions of the eccentric shaft per 1 turn turn of the rotor. Since the output shaft is the eccentric shaft, there is 1 power "stroke" per revolution of the output shaft which is the same as a 2 stroke engine.
Edited by D_Stirls
C17
Snap, seen that before the Defence Air Show in 07 :D
Im officially "touring spec" at the moment
Sub box is being modified / re-designed this weekend, cos i got a bargain
Custom Sliding Drawer System for GQ Patrol (not properly in yet, still gotta bolt it all down and put a couple of dress panels in
Buttload of snatch straps - 2x 4t, 2x 2t, 2x1.2t straps, a snatch block and tree trunk protector, plus a heap of D shackles. Got a couple of different height tow hitches too, and a polyaire exhaust jack
ARB Touring roof rack (put in spot with a crane cos it was easier than trying to lift it lol)..........so now i got somewhere to put extra bits and pieces w00t
Edited by Matty 31
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
