theyre stupid is what they are.
and i cant even put into words how properly ridiculous this thing would be;
Years ago a Peripheral ported 26B, 4 x rotor job won Le Mans. If I remember correctly rotas were banned soon after
Rotarys are effectivley a 2 stroke engine (even thought they don't actually have a stroke) that is why they use more fuel but that is also why they produce so much power with such small displacement.
How about these apples;
Edited by D_Stirls
oh, ive bought a set of pads for the s14 as i can hear the current ones squealing, nothing special, just something to keep my brakes going til i get my qfm's and rda's, but uh... ive never changed pads on 4 pot brakes before, so would anyone be willing be help out?
they are the easiest setup to change i have encountered. the rears require a bit of fiddling to "screw" the piston back in, but they are still 10 times easier than my ford rears that also screw in and you need a special tool to do it (which i didn't have).
3 sided rotor is kinda like having a 3 cylinder 2 stroke with rotor apex seal opening/closing ports as seal passes/exposes the port
Yeah sucked big time. I still think the best days were when we had BMW's, Volvos, Ford Sierras, GTR's in the ATCC
Holden v Ford is a little boring imo
Word to mutha..... its a boganfest atm.... the group A's were much more interesting to watch.... too many rules in motorsport these days. I just wish it didn't come down to R&D budgets.... I reckon some of the early grand prix's in the 30's would be more interesting to watch than todays F1..
-D
-D
F1 which I've been following for nearly 25 years now has been pretty good still up until the last 4 or 5 seasons. Cutting capacity back to 2.4L V8 from 3L V10 and then the engine development freeze and then controlled ECU and now they've f**ked 'em up with new aerodynamics. Should be an interesting first few GP's this year....
Yep there is 3 power "strokes" per 1 revolution of the rotor but there is 3 revolutions of the eccentric shaft per 1 turn turn of the rotor. Since the output shaft is the eccentric shaft, there is 1 power "stroke" per revolution of the output shaft which is the same as a 2 stroke engine.
Edited by D_Stirls
C17
Snap, seen that before the Defence Air Show in 07 :D
Im officially "touring spec" at the moment
Sub box is being modified / re-designed this weekend, cos i got a bargain
Custom Sliding Drawer System for GQ Patrol (not properly in yet, still gotta bolt it all down and put a couple of dress panels in
Buttload of snatch straps - 2x 4t, 2x 2t, 2x1.2t straps, a snatch block and tree trunk protector, plus a heap of D shackles. Got a couple of different height tow hitches too, and a polyaire exhaust jack
ARB Touring roof rack (put in spot with a crane cos it was easier than trying to lift it lol)..........so now i got somewhere to put extra bits and pieces w00t
Edited by Matty 31
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
