im fking angry!
some wanker in a maroon 32 got full dori spec off brighton road into a side street (handbrake and all) the fk stain was doing about 80
i had to dive back on to the pavement, got a few cuts n grazes.
if you are on here, i saw your face, i know your car.....
Ohh wtf thats is just careless
glad that you got away with only cuts and grazes mate
More Kat Von D
much love for kat, you know she'd be an out there chick, and that shits just awesome, beats the hell out of a boring chick who refuses to try anything fun.
Most definitely.
"No boring bits!" :D
+1 shes hot... but too many tats for my liking too.
Had a chuckle not too long ago ...
Went on a night out with some mates, and was told I may not get in to some places due to my tattoos. I carried on about "you discriminating against the colour of my skin?" :) Ah, I guess it was one of those 'had to be there' moments :D
My point being, I blind man wouldn't find her tatts offensive. Its just skin and skin colour dude. :D
true ruby, very true
Id hit it.
lol
hey carl thats f**ked up dude,
yeah i know... im about to go for a bit of a cruise around the neighborhood, and see if i can find him for a chat.
injuries arent bad at all, just a bit shook up
its almost like she fell asleep while working a printing press for womans day and ended up getting sucked into the machine and printed with the gossip section, the agony aunt column and some pictures of angelina jolie...
-D
i might duck out back and cut up some aggh green ranger errrm and choof it down via mr.billeh
ahh hem
stag is with shaun today, on the dyno, told him couldnt afford anything more than a small tune atm tho.
really need to grow my own :) , .......
you never know Tangles, Shaun might look after you and do you a tune for cheap, seeing as you had heaps done there before!
ahh he does, he does :)
they are top lads down there
I cant see the bill being that much, $70 for shaft off/on, then basic dyno charge $80~
as I say to them, look after me and i go no where else, and am nothing but a patient understanding & (hopefully) good customer
query for the hardcore wastelanders
is there a market in SA for custom ecu eprom tunes?
something Im thinking of learning and doing...... learn on mine and then offer basic maps/install for others?
I would arrange dyno time, write a base map, check it out and write a remap... use 2-3 chips per customer, should only be a $300 all up customer cost?
a good emprom usb writer and a bunch of chips and adapters would be a grand start out costs
problem is the chips & adapters..... cost is around 15$ ea non-rewritable chips but adapters are 100 plus the soldering in .....
but yeah, sometime when Ive got 600hundrey to muck around with (tax?I paid extra the past 2yrs) I'll buy a eprom ecu burner and some of my chips, and muck around with it
"Chat" with him about a bit of road manners :)
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
