im fking angry!
some wanker in a maroon 32 got full dori spec off brighton road into a side street (handbrake and all) the fk stain was doing about 80
i had to dive back on to the pavement, got a few cuts n grazes.
if you are on here, i saw your face, i know your car.....
Ohh wtf thats is just careless
glad that you got away with only cuts and grazes mate
More Kat Von D
much love for kat, you know she'd be an out there chick, and that shits just awesome, beats the hell out of a boring chick who refuses to try anything fun.
Most definitely.
"No boring bits!" :D
+1 shes hot... but too many tats for my liking too.
Had a chuckle not too long ago ...
Went on a night out with some mates, and was told I may not get in to some places due to my tattoos. I carried on about "you discriminating against the colour of my skin?" :) Ah, I guess it was one of those 'had to be there' moments :D
My point being, I blind man wouldn't find her tatts offensive. Its just skin and skin colour dude. :D
true ruby, very true
Id hit it.
lol
hey carl thats f**ked up dude,
yeah i know... im about to go for a bit of a cruise around the neighborhood, and see if i can find him for a chat.
injuries arent bad at all, just a bit shook up
its almost like she fell asleep while working a printing press for womans day and ended up getting sucked into the machine and printed with the gossip section, the agony aunt column and some pictures of angelina jolie...
-D
i might duck out back and cut up some aggh green ranger errrm and choof it down via mr.billeh
ahh hem
stag is with shaun today, on the dyno, told him couldnt afford anything more than a small tune atm tho.
really need to grow my own :) , .......
you never know Tangles, Shaun might look after you and do you a tune for cheap, seeing as you had heaps done there before!
ahh he does, he does :)
they are top lads down there
I cant see the bill being that much, $70 for shaft off/on, then basic dyno charge $80~
as I say to them, look after me and i go no where else, and am nothing but a patient understanding & (hopefully) good customer
query for the hardcore wastelanders
is there a market in SA for custom ecu eprom tunes?
something Im thinking of learning and doing...... learn on mine and then offer basic maps/install for others?
I would arrange dyno time, write a base map, check it out and write a remap... use 2-3 chips per customer, should only be a $300 all up customer cost?
a good emprom usb writer and a bunch of chips and adapters would be a grand start out costs
problem is the chips & adapters..... cost is around 15$ ea non-rewritable chips but adapters are 100 plus the soldering in .....
but yeah, sometime when Ive got 600hundrey to muck around with (tax?I paid extra the past 2yrs) I'll buy a eprom ecu burner and some of my chips, and muck around with it
"Chat" with him about a bit of road manners :)
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
