holly crap chad
thats a heap of oil in the IC mate
i have heard of this happening a lot to track cars...
i guess catch can would be a good way to solve this problem...
how does oil get into the air intake system? my guess would be a leak in the turbo section...
-D
yes, but a correctly fitted catch can! I have a link somewhere here in the wasteland.
Chad, heres a pic of an RB25 that represents a decent track setup, open to atmosphere.
so my catch can has two hoses, both connected to each cam cover (replacing the U shaped pipe) so ill be blocking the positive crankcase ventilation valve (so the pcv valve isnt open off boost, sucking air through the catch can) and inlet to turbo from the cam cover.
Yay ... I get to pour more foundations this weekend for my house extension :) The extension is 9.7m x 10.6m, just to give you an idea of the steel frames being erected. Finished off the first frame (there are four) Wednesday night, and its dead straight and level. So glad my surveying skills work eh :)
Tonight I move the gazebo and clothes line. Tomorrow I bore the holes and erect another frame. Hope to have all the framing done this weekend. Roof up next weekend ;)
So thats the plan for the next week, including my mountains of TAFE work, homework and work work! :O
-D
When there's quite a bit of blow-by.
If you're going to have an atmospheric catch can set up be sure to have a suitable baffle that can absorb oil well so as to minimise the amount of oil that will layer your engine bay.
you really like to erect things :)
My erections are so big, I need council approval before beginning ;)
they'll never approve it, your erection is more than 2 storeys high in a zoned residential area
with an erection that big you should have bought in an industrial zoned area
-D
-D
I can have an erection 2 storeys high in a residential area, so long as there are no overlooking issues, and I keep my erection setback from the boundary by at least 900mm. I must also maintain over 100m2 of open space in my back yard, so my erection doesn't get in the way of play space.
However, my erection may raise (no pun intended) overshadow issues with our eastern neighbour. He might not approve of my erection. So it will have Category 2 building approval for an erection of this size :wave:
suprised you didn't make a thread about it :P
I was going to. But it doesn't fall into the category of child birth, or jokes, or villis, or birthdays, or stereo installs, or holidays, or long weekends ... All my threads get closed nowdays anyway. :wave:
Edited by RubyRS4
does your erection need to be at least 1km away from primary schools?
My erection is of a residential nature and the land is therefore correctly zoned to be erected within any proximity of a school (there are two schools less than 200m in either direction from my property). So my building erection is permitted near schools :wave:
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
