I used a baffle plated cat to get through regency... never drove it hard the whole way there and back.
if you have a baffle plate and drive it hard then
the exhaust before the baffle plate will get hotter then the piping after the plate
that way they can tell....and defect you again for having a "non working/colapsed cat"
be careful with those mate
bahaha, profit.
We got a new vending machine at work, thought to myself, hmm, i fancy a kit kat.
Put $1 in, registers on the screen, drops into the coin return, ok. Put $1 in again, $2 comes up on the screen, coin drops back into coin return, brilliant! Select kit kat, viola, paid $0 for my kit kat :banana:
bahaha, profit.
Put $1 in, registers on the screen, drops into the coin return, ok. Put $1 in again, $2 comes up on the screen, coin drops back into coin return, brilliant! Select kit kat, viola, paid $0 for my kit kat :D
Get me a few while you're there :banana:
bahaha, profit.
The coke machine at work was giving everyone 2 cans at a time for about a week..... the bastards fixed it on Tuesday!!!
i know that with the newer coke bottle machines, the one with the conveyor belt, if u hold the flap closed and it doesnt push the coke out, it will drop another coke onto the belt then push both out. i saw a guy do it once :banana:
http://www.spike.com/video/how-to-trick-coke/2862499
Hey Chad if you want i can bring that 32 catch can to Villi's if your going. Give you a starting point at least.
Yeah, that would be awesome, we'll see i there is any room to fit it :banana:
lol Chad, oil is meant to go into your sump not your IC :D
Seriously though, with all that oil in there, were you monitoring your knock count on the PFC while going around Malalla?
Yeah i did, after every session i would have a look at the max's and there was nothing to bad.
Just went and got some degreaser, so gonna go give it a clean up and do an oil change ready for tommorow ;)
fark me, friday 13 th must be my lucky day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i just won x2 4 day reserved grand stand seating + pit entry tickets + a harley ride in the drivers parade
on nova, all i had to do was sms the name of the driver
who won the first ever clipsal 500, of course, twas craig lowndes.
bout time i won something.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
