as stated friday, i won 2x 4 day passes,main strait grand stand, and cant attend thurs fri, so, if you can promise ill have both passes
back friday night, ill be happy to lend them out, providing i know who you are lol
im just lookin forword to the harley ride round the track lol
if you trust me id like to borrow them and give em back to you friday arvo :blink:
do you want some kind of $ for them for the two days ?
na mate, just promise ill have them back friday night :blink:
unless you feel the need to buy me a 4 pack of 500ml beams :blink:
i have some wanker in a white 33 m spec being a wet weather hero round my place atm, good on ya, asshat!
na mate, just promise ill have them back friday night :)
unless you feel the need to buy me a 4 pack of 500ml beams :P
haha , i could drop you a 4 pack next week when i get paid ?
but yep you will have the passes back friday night :)
i dont plan on attending the concerts , just wanna see the races and the pit paddock
pm me whens good to pick them up , i think i remember where you live :P
I'll be there too Pete :P
whoresum. basically every mod is going to be there.
i predict a busy evening when you all get back home if someone starts a thread trying to sell a muffler. :P
Bugger!
Getting the work done my on 'erection' only to hit a snag. Got both outer frames up and foundations poured for the extension, only to come across this when boring the holes for the inner frames:
Farking water pipes!!!
They weren't on any of the plans for this house. Mind you its a 1960s home, so its prob not documented. Now me and the mad scientist gotta get a plumber/gasfitter out to identify and re-route these lines away from my foundations!
:P
BTW
Anyone got a cement breaker bar or similar for breaking up cement some 2" thick. I wanna remove portion of the path to the backyard.
Hoping to have the roof on by next weekend. Doesn't look like its gonna happen until I sort the water piping out.
More farking money to spend!
:P
Hmmmmmmmmmm *ponders*
:P Nah I wouldn't, although I'd have to say I'd laugh so hard if someone did :)
Also, goddam I hate it when you let someone know you are rediculously keen on their vehicle, and they don't get back to you in any way, shape or form. The dude was online and when I sussed his profile he was 'using member control panel' so he was reading my PM, yet no reply in sight. At least tell me if you're not keen for a swap so I don't get my hopes up FFS.
BTW
i have a 9" grinder with some cement blades, sledgehammer and a big 6'crowbar if you need them?
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
