lol, like a home away from home for me unfortunately, but you're right, something about court rooms that you never get to like.
huh, obviously not your affidavit so why didn't you argue it if you didn't agree with it.....unless it was accurate and you were telling little porkies, yeah :P .
You're allowed to take written material with you on the stand and refer to it regularly by stating you don't recall a case of events.
Anyone who doesn't keep accurate records along the way in written form is wasting their time in court, they'll tear you apart in 60 seconds if they know you don't recall exactly what took place......all 'T's must be crossed and all 'I's must be dotted otherwise don't bother taking time off work to go and just pay up.
Why would I tell porkies? And who said I wasn't prepared with documents and photos? Were you there?
I had a choice to make and a simple one at that, cop 3 demerits and a fine for doing nothing wrong or.... spend an incredible amount of money on a lawyer and take a chance that I'd win. Not a chance I was willing to take. The only thing I did wrong was believe that we had a justice system.
Like I said to the judge that day after I stepped of off the stand, I wouldn't have been there if I knew I was in the wrong, I would've happily copped it on the chin if I deliberately broke the law and got caught.
You didnt get defected on south road just after the expressway exit did you? If so I spotted you yesturday morning :P.
yep, pulled over into the bus stop just past the expressway
got spotted by half the guys i work with, so when i rolled in 5 mins late i didnt have to explain myself
^ Funny I haven't seen you any other morning (though i don't really keep an eye out for patrols..). At least once a week I see someone pulled over between there and Castle Plaza.
i was running late as it was (im usually thru there 15mins earlier) driving to the etsa depot on ayliffes rd
slept in, was cold, and then to cop that LOL
anyone know whats happening around South rd/cross rd. Got a 7news chopper in the sky just wondering around.
EDIT: dont worry, burst water main in the middle of the rd has blown a hole in the rd lol
Edited by Luke_ENR34
haha no I wasn't there, lol (all the info is on a public register anyway).
So you still haven't said whose affidavit it was and why (if you did nothing wrong) you didn't contest it yourself.......you don't need a lawyer if you were as prepared as you say you were. It's worth a crack while you're already there if it means saving some $$ and 3 points possibly....what did you have to lose, you're already there and prepared??
If anyone is interested here are some of my new tracks.
Made from scratch. no samples at all.
some weird electronic stuff. deep house. progressive. dark etc
new_house.mp3
ooh_ooh_ahh_ahh__remix1_.mp3
chocolate_chip_shit.mp3
[20:31] Dohmar: http://www.smouch.net/lol/
[20:31] Cara: what is it
[20:31] Dohmar: funny site
[20:32] Dohmar: Never gonna give u uuuuuuuuup
[20:32] Dohmar: Never gonna let u dowwwwn
[20:32] Dohmar: Never gonna tuuuuuurrrrn arouuuuunnd and
[20:32] Dohmar: deserrrrt youuuuuu
[20:32] Cara: f**k U BEN
[20:32] Dohmar: rofl
>:ermm:
-D
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
