my house mate told me yseterday that he brakes are making noise....
just had a quick look, i think i can see the problem...
can u say metal on metal?
those are the deepest grooves i have seen on a disc, they are about 3 - 4 mm deep
yeah looks good Matty but don't know how comfy the Patrol boys would be having a 200 around..........lol, it won't matter whether I can keep up with them or run rings around them, the fact that it's a 200 will get me flamage.
EDIT: Not to mention that I'm still running the factory Dunlop Grandtreks (crapiest tyre ever designed for a 4WD). Need to put some M/T ATZ's on there but I'd be looking at almost 1/2 grand a corner :D
i dont think they'd mind. someone always brings a mate along with another make of 4wd, there tends to be floaters with pajeros, cruisers and the likes. even on the Patrol Club of SA outings they've had Jackaroos and Subaru 1800 wagons :(
Im keen to see how the new Kelly Safari Trex go
i want some custom slots like that in my rotors too. it has a great feature of screaming like a banshee all the time... i need that too
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :D
-D
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :(
-D
unsubstanicted clap trap i dont appreciate that post there is nothing wrong with RDA rotors its the pads and how you bed them in
dont take this the wrong way
haha cheers craig :D
I never said anything about RDA rotors except to buy them. I've ordered some myself... WTF kinda high horse are u on today? Don't appreciate what post?
-D
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
