my house mate told me yseterday that he brakes are making noise....
just had a quick look, i think i can see the problem...
can u say metal on metal?
those are the deepest grooves i have seen on a disc, they are about 3 - 4 mm deep
yeah looks good Matty but don't know how comfy the Patrol boys would be having a 200 around..........lol, it won't matter whether I can keep up with them or run rings around them, the fact that it's a 200 will get me flamage.
EDIT: Not to mention that I'm still running the factory Dunlop Grandtreks (crapiest tyre ever designed for a 4WD). Need to put some M/T ATZ's on there but I'd be looking at almost 1/2 grand a corner :D
i dont think they'd mind. someone always brings a mate along with another make of 4wd, there tends to be floaters with pajeros, cruisers and the likes. even on the Patrol Club of SA outings they've had Jackaroos and Subaru 1800 wagons :(
Im keen to see how the new Kelly Safari Trex go
i want some custom slots like that in my rotors too. it has a great feature of screaming like a banshee all the time... i need that too
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :D
-D
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :(
-D
unsubstanicted clap trap i dont appreciate that post there is nothing wrong with RDA rotors its the pads and how you bed them in
dont take this the wrong way
haha cheers craig :D
I never said anything about RDA rotors except to buy them. I've ordered some myself... WTF kinda high horse are u on today? Don't appreciate what post?
-D
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
